Traction Control Light
Old Oct 17, 2019 | 12:28 AM
Doorman50's Avatar
1999 ML320
I have a 1999 ML30 with 108k miles on it. Recently, the traction control “triangle” warning light came on (flashing). It felt like something was “happening” on the left rear wheel. This has happened a few times only when I make a left hand turn and does not happen all the time. The light stays active for a few seconds, then goes out and the car drives normal. It does not happen every time I make a left hand turn. Any ideas what is going on here? Many thanks in advance.
Old Oct 17, 2019 | 02:51 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You must have a scanner that is capable of reading codes in the ESP Cont. Module.
File Type: pdf
Old Oct 17, 2019 | 10:51 AM
Doorman50's Avatar
1999 ML320
Thanks for the quick reply Mjr Dundee. You are the best. I am having some trouble navigating this site. This is the reason for the double post and possible double response. I will take the ML to my mechanic to checkout what is wrong. I don’t have the equipment to check the codes. Many thanks again.
