2005 ML350 windshield wiper problem
Old Nov 10, 2019 | 05:22 PM
easybeeks's Avatar
2005 ML350
I have another problem you might be able to help with and it concerns windshield wiper speeds. There are three speeds, The middle speed doesn't work and when you change from one speed to another the wiper stops in the middle of the window. Thanks in advance
Old Nov 10, 2019 | 07:23 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
It's not a fuse or relay issue.
Have to ask this question, does this prob. occur while it is raining?
Old Nov 10, 2019 | 07:28 PM
easybeeks's Avatar
2005 ML350
It happens all the time, dry or wet
Old Nov 11, 2019 | 05:34 AM
My guess would be that there is a prob. with the right stalk While it is in the problem setting, ever so slightly move the stalk upward and see if the wipers work. If not, do the same in the downward position.
Old Nov 11, 2019 | 06:48 AM
easybeeks's Avatar
2005 ML350
Thanks for your sugestion but I am a bit confused by your directions. Does the "stalk" refer to the control lever on the steering wheel?
Old Nov 11, 2019 | 04:52 PM
The right stalk on the right that controls the wipers.
Old Nov 11, 2019 | 05:15 PM
easybeeks's Avatar
2005 ML350
ok will try when my daughter comes home again with her car
