Power steering
Old Feb 15, 2020 | 08:11 AM
Habil's Avatar
93 W124 2.5TD
Power steering
Hello, When I started my 2002 ml270cdi yesterday I heard a squeak which I think was the accessories belt slipping. I then tried to turn the steering wheel and found that it was nearly impossible. Any help would be appreciated.
thanks in advance
Old Feb 15, 2020 | 12:04 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Well why haven't you checked the fluid level in the power steering reservoir?
File Type: pdf
Old Feb 15, 2020 | 01:36 PM
Habil's Avatar
93 W124 2.5TD
I have checked the fluid level it was above min and I did try topping it up but no difference. Also I’m in the uk and the cars in Spain so can’t do much checking
Old Feb 15, 2020 | 02:47 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
When posting for assistance, it's best if:
- you provide some background history of your issue and what checks/ investigation/ work you have already performed.
- you are near your vehicle. You in the UK and your w163 in Spain isnt helpful to anyone.
Old Feb 15, 2020 | 02:55 PM
Habil's Avatar
93 W124 2.5TD
I did use the search function but didn’t find anything resembling my problem
I was asking for suggestions, if you can’t help why waste your time replying?
Old Feb 15, 2020 | 03:34 PM
khomer2's Avatar
WOW!
That is not what I asked.
I simply asked/suggested, "...you provide some background history of your issue and what checks/ investigation/ work you have already performed."
How do any members know what you have checked or not checked already, as in the example of Dundee asking you if you had checked the fluid level, the first simple task to look into.
You did not even mention that you already performed this simple task prior to asking for assistance, did you....
You stated, "....I heard a squeak which I think was the accessories belt slipping."
did you actually investigate it! (
I'm presuming no, since you're not anywhere near your suv)
AND since you are not anywhere near your vehicle to follow thru on any advice, how does that assist you at this point?
With your attitude, perhaps go LEARN how-to use the search engine here or on google.
I've already found similar issues on the net pertaining to your issue, but hey, no point in providing them at this point.
GL, Im sure others can assist you.
Old Mar 11, 2020 | 09:12 PM
IgorE350's Avatar
01 ML55AMG 04 ML500 03 ML350 08 ML63AMG
Maybe your power steering pump kicked the bucket? Sounds like pump locked up thats why you heard squeaking noise? id start there.
