Need some help
A couple of months ago, I stopped getting cold air, it doesn't matter how cold I set my temperature, I only get hot air now.
Attached are the codes that I get when I scanned my ML320. I know about the first code - it's just a hose I have to change.
I'm more concerned about the last 5 codes about my AC.
My scanner is a Matco Maximus 2.0
Any thoughts on where I should start?
Thank you
So to solve this issue you must replace the pump first and then the AAC Module, used, new is too expensive.
Post your full vin# for proper parts.
As for the pump make sure you choose one with the right number.
Make sure that you get the radio keys. After installing them push the keys outward and pull the radio out. Do not disconnect the radio if you do not have the code.
