ML55 2002 - GCC SPEC - NO CRANK -NO START ERROR - ALL ELECTRICAL COMPONENTS WORKING
Dear Folks,
First of all I would like to thank each and everyone here for their wonderful contributions. God Bless.
My ML55 does not start, no crank, but all electrical components are working.
Have a parasite drain, which usually kills my battery, and used to jump start.
One day after 2-3 cracks during jump start, no more crack, thought my jumper battery was dead.
Got it charged up, tried to start, no crank, after turning key from 2 to 3 position.
Went through most of the related posts. Cant get my head around this.
DAS led 👍
Starter 👍
Fuses 👍
Gave it to a Mercedes mechanic.
Couldn't figure out, so he fixed a switch near the ignition , after turning the key to position 2, pressing the switch would start the ML55 after couple of tries.
Got scanned by Autel Maxisys from a local workshop.
ME2-SFI MOTOR ELECTRONICS 2 -3 FAULTS
P0410 CURRENT SECONDARY AIR INJECTION (AIR) FAULT (FUNCTION CHAIN)
P0335 MIL ON& CURRENT L5 CRANKSHAFT POSITION SENSOR (CPS)
P0341 NOT DEFINED B6/1 CAMSHALF HALL EFFECT SENSOR
ESP- ELECTRONIC STABILITY PROGRAM 4 FAULTS
C1320 CURRENT COMPONENT Y10 SPEED SENSITIVE POWER STEERING SPS/PML SOLENOID VALVE IS FAULTY OR THE WIRING TO THE COMPONENT HAS AN OPEN CIRCUIT
C1140-12 MIL ON& CURRENT N49 STEERING ANGLE SENSOR (SAS)
C1142 MIL ON& CURRENT B24/2 ESP LATERAL ACCELERATION (LAS)
C1000 STORED N47-5 ESP,SPEED SENSITIVE POWER STEERING SPS/PML AND BRAKE ASSIST SYSTEM BAS CONTROL MODULE
ICM-INSTRUMENT CLUSTER WITH MAINTENANCE INTERVAL DISPLAY - 2 FAULTS
B1042 STORED FAULT IN CAN COMMUNICATION WITH THE CONTROL MODULE -BRAKE ASSIST SYSTEM
B1039 STORED FAULT IN CAN COMMUNICATION WITH THE CONTROL MODULE -TRANSMISSION CONTROL
VG TRANSFER CASE 1 FAULT
P1831 STORED POSITIONER MOTOR OR POSITION SENSOR OR POWER SUPPLY IS FAULTY
BAS BRAKE ASSIST 1 FAULT
C1000-055 STORED N48 (BRAKE ASSIST SYSTEM (BAS) CONTROL MODULE)
EAM EXTENDED ACTIVITY MODULE 5 FAULTS
B1040 STORED CAN BUS COMMUNICATION FAULT - ENGINE CONTROL MODULE
B1086 STORED CAN BUS COMMUNICATION FAULT - ALL ACTIVITY MODULE
B1041 STORED CAN BUS COMMUNICATION FAULT - ELECTRONIC STABILITY PROGRAM / ELECTRONIC TRACTION SYSTEM
B1089 STORED CAN BUS COMMUNICATION FAULT - *** TRANSFER CASE (VG) RANGE SELECTION MOTOR
B1642-0 STORED LEFT LOW BEAM -OPEN CIRCUIT , SHORT CIRCUIT TO POSITIVE
AAM ALL ACTIVITY MODULE 5 FAULTS
B1040-007 STORED&CURRENT CAN BUS : COMMUNICATION FAULT B38 RAIN SENSOR
B1784-002 STORED THE CENTRAL LOCKING (CL/ZV) SIGNAL CONTACT PASSENGER DOOR PROVIDES IMPLAUSIBLE VALUES- FAULT DURING LOCKING
B1788-002 STORED THE CENTRAL LOCKING (CL/ZV) SIGNAL CONTACT RIGHT REAR DOOR PROVIDES IMPLAUSIBLE VALUES- FAULT DURING LOCKING
B1040-008 STORED CAN BUS : COMMUNICATION FAULT: CONTROL MODULE AIR CONDITIONING
B1783-001 STORED THE CENTRAL LOCKING (CL/ZV) SIGNAL CONTACT DRIVER DOOR PROVIDES IMPLAUSIBLE VALUES- FAULT DURING LOCKING
COMAND -2 FAULTS
N1111-0 STORED NO DATA IS TRANSMITTED BETWEEN DIGITAL DATA BUS D2B MASTER AND A DIGITAL DATA BUS D2B COMPONENT: THE COMPONENT AT LOCATION 0 REPORTS A FAULT IN THE DIGITAL DATA BUS D2B RING
B1738-4 STORED&CURRENT NAVIGATION FAULT : THE CABLE ANTENNA BETWEEN THE COMPONENTS GPS ANTENNA AND A40/3N2 NAVIGATION PROCESSOR HAS A OPEN CIRCUIT IN THE WIRING
CDC-CD CHANGER -1 FAULTS
N1118 STORED FAULTY INITIALIZATION BY DIGITAL DATA BUS (D2B) MASTER
AAC AUTOMATIC AIR CONDITIONING 5 FAULTS
B1105 STORED&CURRENT A9 A/C COMPRESSOR
B1107 STORED&CURRENT REAR WINDOW DEFROSTER
B1206 STORED M2/12 REAR SHUT-OFF FLAP POSITING MOTOR
B1302 STORED FAULT IN CAN COMMUNICATION WITH THE CONTROL MODULE LOWER CONTROL PANEL(LCP/UBF)
B1306 STORED FAULT IN CAN COMMUNICATION WITH THE CONTROL MODULE N30/4(ESP CONTROL MODULE)
DRIVE AUTHORIZATION SYSTEM -1 FAULTS
B1703-000 STORED THE TRANSPONDER CANNOT BE READ
Please help.
God Bless 🙏
DAS led 👍
Starter 👍
Fuses 👍
COMAND -2 FAULTS
Please help.
God Bless 🙏
2002 ML 320 & 2006 ML500
What does this mean?..............Couldn't figure out, so he fixed a switch near the ignition , after turning the key to position 2, pressing the switch would start the ML55 after couple of tries.
All of those codes must be deleted. Then check for codes again.
soulblade046 (08-08-2020)
Code cleared and rescanned with MaxiAP 200
Dear Dundee,
Got MaxiAP AP200.
Cleared codes as advised.
Below are the existing codes after clearing.
1.1. C1320 Component 'Y10 (Speed-sensitive Power Steering (SPS/PML) solenoid valve)' is faulty or the wiring to the component has an open circuit
Current
1.2. C1140-12 N49 (Steering Angle Sensor (SAS))
MIL ON&Current
1.3. C1032 Fault in CAN communication with the control module 'Instrument Cluster'.
Stored
1.4. C1000 N47-5 (ESP, Speed-sensitive Power Steering (SPS/PML) and Brake Assist System (BAS) control module)
MIL ON&Current
1.5. C1142 B24/2 (ESP Lateral Acceleration Sensor (LAS)
MIL ON&Current
2.1. B1042 Fault in CAN communication with the control module'Brake Assist System'.
Stored&Current
3.1. B1642-0 Left low beam :Open circuit , Short circuit to positive
Stored
4.1. P1747 Defective Interaction of CAN With Control Unit A1(instrument cluster)
Stored
4.2. P0410 Scondary Air Injection (AIR) : fault ( function chain)
Current
Hope this is helpful
Got MaxiAP AP200.
Current
MIL ON&Current
Stored
MIL ON&Current
MIL ON&Current
Stored&Current
Stored
Stored
Current
BIG QUESTION: SNCE THE DEALER SAID MY AAM is not communicating and they can not replace it (obsolete), can I replace all my computers with a used set from another car including the key, will that work since everything is synchronized/proprietary. No one in the Dallas area has any good news for me about the 2004 ML350 being able to be repaired. Does anyone have any suggestions, good interior, body, paint, new tires, good engine/tranny but I can't start it or go anywhere?
