P0455 Not gas cap, what else can I check before smoke machine?
Old Sep 16, 2020 | 11:37 AM
norcalcasey's Avatar
2006 C55, 2004 ML350
Hi all,
2004 ML350 4JGAB57E64A497435 is the VIN.
Last week I got the P0455 (evap large leak) code, so I searched and saw that the gas cap is a common fix.
I replaced it with an aftermarket and the code came back yesterday. I whipped out my scanner and found the following codes.
P2013-2 Major leak in purge system. Hose in system not connected or filler cap open.
Where can I check before paying the indy to use the smoke machine?
Old Sep 16, 2020 | 06:44 PM
wbrokow1's Avatar
ML430 2001
I had a leak on the gasket on top of the puel pump. gave a evap error code. Replaced gasket and it went away.
Old Sep 17, 2020 | 07:58 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Originally Posted by norcalcasey
Hi all,
There are so many possibilities and the only alternative is the smoke test.
File Type: pdf
Old Sep 18, 2020 | 08:05 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
A DIY smoke machine is a must for any of these older MBs. Will cost you no more than $15-20 and 15 min of your time to build one.
Old Sep 22, 2020 | 02:33 PM
I looked around online, and most of them require an air compressor which I dont have. I called my local indy and they wanted $210 for the smoke test.
Seems expensive to me. Do chain shops (Midas, Meineke) have smoke machines?
Old Sep 22, 2020 | 02:46 PM
khomer2's Avatar
Then build one.
Look up on YT on how-to ==========> 15bucks or less to make one.
