The ML is beeping at my wife
My wife just called and said the ML is "beeping" at her at approximately 10 second intervals. None of the dash lights is indicating any problem. Any ideas what it could be?
Jeff
Jeff
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Could be that she is driving around with the emergency/parking brake on. Ask her to release it with the release handle. Do not know anything else that beeps.
a car that can't do the throttle reset.
2002 Mercedes Benz ML320
is it like a beep and bird chirping sounds? my car got that when i bought it, now it makes longated beeping sounds early in the morning, always involves turning it on, let it run for 2 minutes, shut it off, start it back on, and wallah.... the dealership cant figure out anything worth crap, probably cause all their technitions except for 1 are ford guys that dont know anything about mercedes benz's... grrr
![Mad](https://mbworld.org/forums/images/smilies/mad.gif)
You could be having a trip computer going out. If it thinks the anti tow is on but it is not then you might get the beeping, another words its wire are crossed up and it is confused. This is a long shot though, I would check the parking brake first. Autogunner
Thanks for the help. Whatever it was, it went away. Problem with the trip computer? I installed a (new) trip computer myself about a month ago. It has worked perfectly since. Hmmmm. . .
Jeff
Jeff
SL500 E320 ML350
Jeff
Jeff
Originally Posted by benzboy
Not to worry. I understand it's just the ML's way of showing affection! ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
I finally got to experience the "beeping" for myself. It's not "beeping" at all. The noise emanates from the driver's side air vent, and sounds like a high pitched suck, like maybe a pin hole in a vacuum line. Whatever it is, it's not electrical. Any ideas?
Jeff
Jeff
