New headlamp assemblies issues
Old Jan 14, 2021 | 10:53 PM
clmessores's Avatar
ML 430
I have a 2004 ML 350 that I recently installed a new headlamp assembly on the driver side and have to put a new one on the passenger side. What i am having trouble with is the light beam cuts off fully at the top. We adjusted the height but still the strange cutoff is still there. As you can see in the picture it is right at the top of the where the beam should be. Any ideas what I can do to get rid of it.
Old Jan 15, 2021 | 03:40 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Put the original one back in and see what happens.
Old Jan 15, 2021 | 09:33 AM
clmessores's Avatar
ML 430
That would be a great idea if I could but the original one was damaged.
Old Jan 16, 2021 | 03:42 AM
If it was a knock-off that you installed, it is usually the wiring set-up.
Remove the new one and compare the wiring to the old one.
