Problem with headlights
Old Jan 22, 2021 | 03:38 AM
gogetit's Avatar
w163
Hello, I have a problem with headlights of my ML 400 CDI 2001 year.The combination switch is changed with brand new one. When I turn on the low beam headlights both low and high beam lights turned on. I tried to change AAM module with two other AAM units, but the result is the same. I changed the unit with fuses and relays, where the AAM module is connected , also without results. I tried to move left and right the AMM module and in some position the high beams turned off .
If anyone has had the same problem I would be very grateful if you could help me !
Thank you in advance !
Old Jan 22, 2021 | 07:23 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
When you are having this problem, is the High Beam icon lit on the Instrument Cluster?
Old Jan 22, 2021 | 08:01 AM
gogetit's Avatar
w163
Yes , the icon for high beam lights on when start the low beam .
Old Jan 22, 2021 | 08:12 AM
My guess is that there is a problem with the Combination Switch.
Try this, press the switch to make a left turn, then slightly press the switch downward. Do the high beams flicker or turn off?
Old Jan 22, 2021 | 09:28 AM
gogetit's Avatar
w163
The combination switch is brand new. I forgot to mention it. Now i will do your test
Old Jan 22, 2021 | 01:02 PM
Did you replace the switch because of this problem?
Where did you buy it from and what was the part # ?
