99 ML 430 ,Where to buy a replacement coolant tank ?
Old May 6, 2021 | 03:20 PM
WenzBenz's Avatar
1999 ML430
I’ve had the car for over two years and when I got it all the plastic under the hood was very brittle it’s always had a slow leak and I just topped off the water coolant mixture every now and again. Yesterday went driving in the mountains and the warning low fluid indicator light came on and the tank had sprung three leaks cracks etc. I added water all the way home. It needs to be replaced ASAP Looking for information on where to buy one and is there anything else needed when replacing one. Thanks
Old May 7, 2021 | 05:53 PM
silver ml500's Avatar
ML500
eBay sells plenty of copy ones that are 100% perfect.
I replaced mine as cracked and leaking.
£35 sterling, and it came from Poland.
£75 second hand for genuine ones, but they are also about 20 years old, so will fail also and be brittle.
The entire world sells them, simply google the item you want and pick your supplier.
Fitting them is hassle and time consuming, but DO NOT follow idiots on youtube telling you to remove or move the fuse box, as this is NOT needed to be done what-so-ever.
Windshield Washer Reservoir Tank For Mercedes Benz ML W163 A1638690820 New
https://www.ebay.co.uk/itm/402362087354?ssPageName=STRK%3AMEBIDX%3AIT&_trksid =p2060353.m2749.l2649
racinghavens (2965 )
Ships world-wide, and fits 100% perfectly, and better than the other chinese ones out there.
Old May 7, 2021 | 08:05 PM
WenzBenz's Avatar
1999 ML430
Bought one at AutoZone! Thanks
I was able to find one at AutoZone right here where I live about 55 bucks plus tax going to put it in tomorrow
