Body Control Module Burnt Out Twice
In all probability a live wire is contacting to ground caused by a mouse eating the wire covering.
Remove the fuse box module (PDF) and inspect the wiring related to SV4.
What you are showing is called the EAM - extended activity module.
The cartridge that slides out needs to be transferred to the new module, as it contains your DAS (drive authorization system) info that allows the key to start the car.
AAM attaches directly to the fuse box and EAM is under the dashboard drivers side.
