Automatic Heating
Old Sep 16, 2004 | 11:09 AM
Swiss Nick's Avatar
ML 270 CDI 2002
Automatic Heating
Sitting in the car the other night, with the engine off. Was getting pretty cold, so I decided to turn the heating on (ignition was off, when I discovered that the climate system would not work. If I understand it correctly the system should work until the stored heat runs out or the battery drops below a certain voltage. Well I had just driven for 8 hours, so I assume that everything was OK. It has worked fine in the past when I have left the car to go shopping. Anyone have any ideas??? or is it another trip back to the dealer.....
Old Sep 16, 2004 | 01:15 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Are you talking about the rest switch??
Old Sep 17, 2004 | 12:02 PM
Swiss Nick's Avatar
ML 270 CDI 2002
Rest switch? Not sure what you mean. In the past when I have left the car and turned off the ignition, I press the "Auto" and the heating will maintain the temperature I set until it switches off due to voltage drop or heat loss. Does that help?
Old Sep 17, 2004 | 12:08 PM
emro's Avatar
03 ML500;05 G55;02 CLK 430;2K MRoadster
You said it yourself, if the voltage drop rest switch feature will not work. A possibility that the battery is going?
Old Sep 17, 2004 | 12:11 PM
Swiss Nick's Avatar
ML 270 CDI 2002
Sosh, just checked, yes the "rest switch".
Emro, thanks for the idea, I had thought the same about the battery being the problem. However I had just driven for 8 hours non-stop. When I decided to put the heating on the engine had only be off for about 5 minutes. However I will have the battery tested.
Old Sep 17, 2004 | 12:14 PM
sosh's Avatar
Tried my 02 ML500. Works with the Rest switch but if I just push auto with the ignition off does nothing.
Old Sep 17, 2004 | 12:17 PM
Swiss Nick's Avatar
ML 270 CDI 2002
Sosh, just tried it again, all dead. Will take it to the MB dealer!! Best make use of the warranty!!!
