ML430-1999-Acelarator issue
Old Nov 14, 2021 | 10:17 AM
BECKMBA's Avatar
ML320
Hello I replaced my pedal position sensor and did the reset procedure multiple times. Unfortunately the accelerator is not responding. every time I either use the pedal or the TPS under the hood the engine still does not rev up. It just starts to run a little rough.
Could it be the throttle body ? My question is what does the TPS talk to or connect to? That then communicates with the throttle body.
Any help would be appreciated.
Old Nov 15, 2021 | 11:06 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Try this throttle relearn.
File Type: pdf
