2001 ml430 confused on the side for hard brake lines and unions
Old Dec 9, 2021 | 01:52 PM
Alumnite's Avatar
Ml430
I’m currently replacing the steel brake lines with 3/16th Lines and compression fittings im not sure if these will work. I measure the outer diameter of the line and it came to be about 4.75mm
please let me know how I am doing?!
Old Dec 10, 2021 | 08:58 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Here is an excellent post with replacing the brake lines in the W164 forum. Bear in mind that W163 & W164 lines are exactly the same.
https://www.benzworld.org/threads/ru...e-diy.3080908/
