Help !! Something is wrong !
Old May 17, 2002 | 12:02 AM
JCRamirez's Avatar
99 ML320
Unhappy Help !! Something is wrong !
I recently lowered my 99 ML320 with H&R Springs, and put Michelin 285 VR55 x 18 tires on BBS 18 x 10's. It looks awesome, and handles even more awesome, but something started happening that I cannot explain:
When I take a long sweeper freeway on or off ramp, and take it hard, as in pulling close to a .8 lateral g, the yellow Hazard triangle in the middle of my speedo starts flashing and I hear weird noises coming from the front end. It does not happen when I do sweeper right turns, but only left ones.
Does anybody know what this is or why it's happening? At first I thought that the centrifugal force may be pushing all the oil to one side of the transfer case or the front end but I am not sure. The vehicle has 35k miles and has never done this before. If I drive it normal, it does not do this. Anyone else ever have that happen? I appreciate all responses.
Old May 17, 2002 | 12:07 AM
pocholin's Avatar
Volvo V90 CC
Can't help you diagnose your problem, but I'd suggest having the M-B shop foreman drive it for you.
Old May 17, 2002 | 05:41 AM
Taiichiro's Avatar
98ML320
Talking To JCRamirez
Hi JCRamirez
H&R Springs with 18 x 10's wheel and stock dumper get on worth. When lowered, you must have Bilstein dumper installed.
Stiff Springs and soft stock dumper are mismatch.
Perhaps front tire interfers with wheel house when you sweeper right turn.
Old May 17, 2002 | 09:28 AM
chris's Avatar
2000 ML430
It's your traction control
And the weird noises that you hear are the individual brakes braking each wheel independantly. Also you might want to check your camber adjustment. And if you didn't lower your front end the same as the rear, that could be the cause also. You're shocks could also be the result. I changed everything when I lowered my car, H&R's, Bilsteins and lowered the front bye adjusting the torsion bars, and I have 295/40/20's on my car and the only time traction control comes on is when I take a sweeping curve like that going at dangerous speeds, LoL. Hope that helps
-Chris
Old May 17, 2002 | 10:34 AM
JCRamirez's Avatar
99 ML320
Talking Hmmmmmmmmmm
This makes sense. The noise does sound like the ABS trying to do their thing. I did lower the front end but have not yet gotten the Bilsteins. When I get the Bilsteins, do they have to be shorter than the stock set I would of normally needed ?
And finally, is there any way to get it to stop doing this or do I just have to turn off the traction control?
Taiichiro, what do you mean when you say dumper? Is that same as shock absorber?
Old May 17, 2002 | 08:03 PM
Taiichiro's Avatar
98ML320
Wink >Taiichiro, what do you mean when you say dumper? Is that same as shock absorber?
Sorry
Bilstein dumper means Bilstein shock.
chris is right, the weird noises may be caused your traction control.You had better raise up the front by torsion bar adjustment.
