Side mirror blinker fix?
Old Jun 26, 2022 | 08:15 AM
convicted's Avatar
1998 CLK 320
Question Side mirror blinker fix?
Hello all,
My side mirror blinkers aren't working anymore and I can't seem to find replacements for them anywhere. Does anyone know of a DIY fix, or am I pretty much stuck?
FYI: P/N is: 163-820-04-21
Thanks,
Old Jun 26, 2022 | 10:30 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Remove relay K12 and replace it with similar relay on the board and see if the blinkers work.
Old Jun 30, 2022 | 03:19 PM
convicted's Avatar
1998 CLK 320
I put the hazards on and checked the connection with a DIMM and it was getting proper voltage. That means the LEDs are shot, right?
Old Jul 1, 2022 | 05:54 AM
You say nothing about my suggestion.
Old Jul 1, 2022 | 09:51 AM
hyperion667's Avatar
2012 CLS63
Clearly a low fluid issue which can be resolved quite easily
Old Jul 2, 2022 | 01:08 PM
convicted's Avatar
1998 CLK 320
I understand your suggestion, but didn't I already rule that out by finding voltage at the plugs the LEDs plug into, or am I missing something?
​​​​​​Not possible, I just flushed the entire system and filled it with two quarts of full synthetic blinker fluid.
