ML500 Power Steering Question.
Old Sep 10, 2022 | 08:18 PM
convicted's Avatar
1998 CLK 320
Hello all,
My power steering typically works fine. The fluid level is fine, but it has an intermittent issue where sometimes it will be hard to turn. As if the pump was going out, but I have no whining and it's not always when the truck is idle.
Through my searches, I've seen other people say that these pumps do not go bad. I jacked the truck up, opened the cap and turned the wheels left and right to make sure there were no air bubbles and refilled the fluid to the proper level, but I shredded a serpentine belt the other day and I was not using the air conditioner, so it has me wondering if there's something wrong with the power steering pump or the pulley, as all other pullies seem to be fine.
Can anyone help with this?
Thanks!!
Old Sep 15, 2022 | 06:26 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Is the tightness in the steering for the whole turn or just part of it? My W164 had a problem like this. It turned out to be the knuckle at the end of the steering column that had seized. It would be fine for the most part of each turn and then for maybe 90 degrees is would be as if the power steering wasn't functioning. I think there might be a bulletin on it from memory. I took it back to the dealer as it was under warranty. They laughed at me when I suggested the potential problem. When I picked it up they said "how did you know? We wouldn't have even thought to look there". It might pay to check this out.
Old Sep 15, 2022 | 10:39 AM
convicted's Avatar
1998 CLK 320
It's completely random. I've had a ton of ML owners tell me now that it's normal on many, many MLs.
Old Sep 27, 2022 | 08:54 PM
gkrumian's Avatar
00 ML
Actually ML pumps do go bad. That whole generation of LUK or ZF pumps used by Mercedes/BMW/Porsche are not the highest quality units. Fortunately they're not too expensive and quite easy to replace.
Old Oct 5, 2022 | 04:30 PM
convicted's Avatar
1998 CLK 320
That's good to know and I'm not surprised either. I'm sure I'll end up replacing mine and I'm sure I can figure it out on my own, but if you have a write-up on it that would save me the Google search, I would appreciate it.
