Transfer Case Service
Old Oct 25, 2022 | 09:38 AM
jcakers's Avatar
'85 380SL, '10 E350, '16 GL450
I need to replace the fluid in my transfer case (2011 ML350 4Matic). Do I have to replace the drain and fill plugs as well? I have received different opinions.
Old Oct 26, 2022 | 05:48 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You are on the wrong forum. M/B does not supply how to replace fluid. You must look to You Tube for instructions.
https://www.youtube.com/results?sear...fer+case+fluid
https://mbworld.org/forums/m-class-w164-72/
Old Nov 11, 2022 | 11:52 AM
mRaposo's Avatar
ML350 2009 CDI
I usually exchange the T-Case's oil with the transmission oil exchange service - every 60,000 km.
You don't have to replace the drain and the filling plug.
You should pay attention to the use of the correct oil, which is the Fuchs Titan ATF 3353.
Old Apr 12, 2023 | 07:06 PM
Mt. T's Avatar
W163, W208
I went to MB and got a pint of ATF oil.
