$1300 to replace F/R Brakes pads, rotors, sensors???
Hello All,
My local MB Dealer in Scottsdale, AZ wants to charge $1300 to replace the front and rear brakes. I'm not surprised that I need this done but the price seems kinda of high. Is it?
2000 ML 430
sounds about right for what a dealer would quote...
that's not to say you can't get it done MUCH cheaper... or even do it yourself... (it's pretty straightforward).
parts from germanstar.net are about $400 or so for everything...
CLK 320
If it's pads, rotors and sensors all around, that sounds a bit high but not too much... considering that a good chunk of that is labor. ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
When I had the dealer last do my front pads & rotors and rear pads (and all sensors), parts was $350... labor was $280. No kidding.
2000 ML 430
It takes about 2 hours..
however you slice it, 1300 is WAY too much. germanstar parts are OEM anyways.. so you'll be getting same crap one way or the other
1 Post
4 wheeled car.
Tell your dealer to put down the crack pipe.
Sensors are like $3 a piece, pads like 100 bucks for two pairs (all OEM from mercedes), rotors, I dont know but I'm guessing $140 a pop. Labor, $100 or so.
I would suggest running brembo's they are the best. The place were i bought mine BRAKEWORLD.COM
