Replace Ignition Switch/Ignition Switch Housing
Old Dec 9, 2022 | 02:35 PM
Jerry Easley's Avatar
'00 CLK320, '01 ML320 Designo, '01 ML320 Sport; '04 CLK320 Coupe Avantgar; '04 C230 SportCoupe (HB)
I am planning to replace these two items as it seems the plastic moving parts for holding the key until it is returned to POS 0 is worn. My cylinder and key work just fine outside the housing - but I am having difficulty removing it after starting the car. It 'hang's up'.
I did a search on the forums for a WIS or other type step-by-step but didn't find any.
Is there a resource available?
Old Dec 10, 2022 | 08:46 AM
bttucker's Avatar
2001 SL500, 2017 GLE350
use these search words on youtube: replace w163 ml320 ignition switch
there are many w163 how-tos available
Old May 16, 2023 | 11:21 PM
Thanks for the reply, I am back on this (now that the weather is more warm).
On You Tube I find many posts on how to change the ignition CYLINDER, but none for the actual SWITCH - which is mounted on the steering column. Have already done the new cylinder and key from MB Classics - but am not getting enough contact to "Start". There is a long delay - then it will finally 'connect' and spin the starter - but this week - it gave up complete. I know the circuit works as I jumped the relay and I get good voltage.
After removing the fascia etc it looks to be easy enough while holding the new replacement - but am concerned to 'do it right' so none of the plastic tabs etc are damaged. Plus the space in there is confined to say the least. Is it necessary to lower the column for example? Looking for the 'how-to'.
Today I paged thru WIS on-line and an index, and could not find any AR's, or even SI's.
Still looking for "R&I Ignition/Start Switch" or some past-experience narratives.
Thanks much.
Old May 17, 2023 | 11:24 AM
bttucker's Avatar
You've been here without satisfaction, right?
https://www.benzworld.org/threads/st...2#post-5465784
