front brake squeak
1. There is seperation between the pistons and the back of the pad (anti-squeal paste adhesive didn't hold). Just remove pads and re-apply.
2. You have something other than standard pads (ie, high perf pads) that require higher temp to work optimally and the squealing is normal until that temp is reached.
I would RUN fron that firestone place. I bet they have bets about how much work they can CON you into!
There may be other reasons but this is my best guess now.
Don't skimp, pay the money or DIY. Order up new pads and rotors. You can order you pads and rotors inexpensively if you search the web. If you are not a DIY kinda person then pay the dealer or MB reoair shop. When it comes to these cars, you have three options (that are your safest bet):
1. DIY
2. Dealer
3. Mercedes Repair Facility (non-dealer)
I would NEVER go outside those 3. For example, change your own oil, or pay one of the other 2, unless you want to risk jiffy lube, etc. screwing up your car!
