W163 sunroof stuck fully open
Old Mar 15, 2023 | 06:02 PM
psnevets's Avatar
2017 W166 GLE350, 2005 W163 ML350 Special Edition
I opened the sunroof on my 2005 ML350, drove a few miles, then found that it wouldn't close. It's stuck fully open, I've tried all the usual fixes (reset via pulling fuse 4, etc.). When I attempted to close it via the 4mm Allen wrench into the motor housing, it would not budge. Any good ideas?
Old Mar 16, 2023 | 03:47 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Get on a high ladder and inspect all 4 sides and look for broken piece/s of plastic..
Old Mar 16, 2023 | 04:10 PM
psnevets's Avatar
Thanks for the reply. I have tediously inspected the entire area and can find no debris. Two local indys have not been able to resolve the issue. i fear I'm looking at having to remove (or have removed) the headliner to get at the sunroof "cassette" to determine what's up. Perhaps a broken cable? Whatever it is, I suspect it's going to get expensive!
Old Mar 16, 2023 | 07:59 PM
When you tried to attempt to close it via the 4mm Allen wrench and it did not close, it cannot be an electrical problem.
Old May 8, 2023 | 04:21 PM
psnevets's Avatar
As it turned out, the sunroof module was not worth repairing. I had it removed and replaced with an scrapyard unit.
Old May 20, 2023 | 02:31 PM
farcohollis1369's Avatar
'02 ML500
So replacing the module fixed the problem??
or did you replace the entire sunroof assembly?
Old Jun 7, 2023 | 06:46 PM
psnevets's Avatar
I replaced the entire assembly with a used unit bought from a breaker yard. About $700 parts & labor.
