Cluster backlight problem
Old May 30, 2023 | 03:01 PM
DoMe84's Avatar
w163 270cdi
I have a dumb problem with cluster back light illumination. 2 of the bulbs that illuminate the dials died and I changed all 4 bulbs for LED. One of the LEDs had a short and it burned. I changed that one. Everything was fine until I turned off the ignition. All LED bulbs stay on. I thought it was a problem with LED bulbs and I changed them for original MB bulbs and the same problem appeared. All other lights are fine and working correctly. Dimmer also works. Only problem are those that illuminate the dials. They are always on. Is there any relay on cluster that may have got stuck on.
