how far can i go if brake light just came on
Would it be safe to drive 400 miles if the brake light just came on. Right now it is blinking on and off randomly.
Therefore if in doubt, I'd suggest you check all pads visually for wear before making a long journey - otherwise you may land up with metal on metal and a bill for new rotors :-(
Hope the above makes sense :-)
I mention this because this is nearly what happened on my '00 ML430 - but in my case the wear sensor light was not even lit (probably had another 1000 miles to go), but other pads were just about shot with less than 100 miles left.
Maybe your ML has sensors on all pads ? Something I think all ML's would benefit from.
Tim in San Diego
