The list of stuff to watch out for on a 163
#79
Problem is a fuel system diaphram. My local mechanic figured this out. It keeps pressure in the fuel system after you shut off the engine, and the fuel pump. The diaphram is rubber and gets leaks which release the pressure in the system. Usually if you turn the key to the position just before starting it will energize the fuel pump and pressurize the system. Give it a good 15-30 seconds and then try to start it. If that works then the diaphram is the problem. My mechanic charge about $450 to replace it, parts and labor. Well worth it. A friend's ML430 had the same issue.
#80
2007 SLK 280
ML Cup holders
Great list! And I still like the car? Yes.
I have a drivers side cup holder broken gear. Can anyone help the R&R process to remove for gear replacement?
#81
I Bought a ML320 this week and in the same day my car locked up whilst i was driving had it towed and diagnostic testing - turns to be my alternator. Get the car back driving fine all day yesterday, tonight - ready to go out car starts, shift to D (drive) car moves and now gears are not changing while i driving its like it's stuck in 1st or 2nd gear and sounds like if i accelerate it revs out - can someone kindly help me - im hating my ML320 after 3 days, so not fair.
#82
Natasha - it sounds like the vehicle is stuck in what is called "limp mode", which is indicative of something being wrong, but the car stays in a low gear to allow you to "limp" home [or to a shop or dealer] to have it checked out. You might do a search on limp mode because I am no expert, but I doubt that a bad alternator would cause this. If you have a good qualified independent shop within reach, take it to them. Otherwise, get it to a dealer because no average mechanic will be familiar enough with the ML to help you.
Sorry that I don't have more information to help you.
#83
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
Thank you so much for your help. Yes you are spot on! it is on limp mode. I will endevour to research on limp mode! Thanks again! much appreciated. My mechanic had a ML320 as well and he said the same thing i just dont want to fork thousands of dollars, not even 4 days and these issues are bothering me.
#86
So i have replaced my Electrics kit and everything seemed to be fine. then after i drive out of the mechanics my battery dies on me. i call and get a new battery installed and everything seems to be fine - driving like a dream. the next morning i come to turn my car on and warm it up. as im about to drivie i notice the engine light has re appeared!!!
i got the car rescanned and it showed up speed sensor! what do i do now!! help please!!! i may also mention that there was a small amount of oil on the floor.
#88
Hi everyone, just joining.
This list is awesome. thanks for everyone that helped it.
will be checking one 1998 320 this week. One owner, just out of the extended warranty, or so he says.
the carfax shows
130k miles, FAILED EMISSION INSPECTION
130K+-100, PASSED EMISSION INSPECTION
should I worry about something specific because of this?
the carfax shows
#90
ml320
ml320 fuel filter location.
If I recall,
I took out the back seat, there was what looked like a paint can lid, I popped that off and there was the fuel pump. If it is the newer style it has easy pop off connections, it cracked me up that Mercedes has easy pop off connections on an item you replace once every 100,000 miles. It would be easier if the seat legs had easy pop off releases.
#92
Catalytic converter fix...
"Catalytic converters break in half, or rattle. Replacement required. Must remove torsion bars and reset ride hieght after replacement." Sounds expensive but maybe not.
If the problems above are the result of a bad weld you may be able to save some money by just re-welding the pipe/converter. Evidently the original weld material was not as good as the components and the welds will erode from the inside. I had my driver's side converter break at a weld. Bought an oxygen sensor socket to remove the two sensors and then cranked down the torsion bars (more on that) took the parts to a TIG welder and for $30 he fixed me up. Has lasted for more than 50K / 6 years. Still pass a stringent emissions test.
Removing torsion bars: at first is sounded difficult and dangerous. In fact removing the torsion bars are far easier than removing the coil springs on most cars (especially the ML). I imagined that it would take multiple turns to release/install. Nope its probably like 30 degrees. Suggest that you park car on level surface, rock it side to side to settle the suspension. Find a place on the front outer edge to take a good measurement of the ride height. Take tons of pictures. Mark the head of the bolt and start to unscrew counting the full turns as you go. At a certain point everything gets loose and you can pull the bar out of the socket. Assuming no one messed with the parts you can reassemble and just re-tighten turning the bolt the same number of turns as before. The socket end of the bar is a hex (maybe square on some cars) and you won't have to worry how to index the bar; the right position will be obvious. Attempting to install the bar one flat off will obviously be out. After you have tighten the adjustment screw drive around the block and park in the same place. Your ride height should be the same as before.
#96
ML320 PETROL 1999
THANKS FOR THE LIST OF COMMON PROBLEMS AND SOLUTIONS.WOULD YOU PLEASE HAVE ANY SOLUTION TO MY PROBLEM WITH MY ML320,MY HORN JUST STARTED BLOWING ON ITS OWN FROM NOWHERE ONE DAY ,IT WOULDN'T SWITCH OFF UNTIL I PUT THE IGNITION KEY TO START POSITION AND OR WHEN I START THE CAR.
THE ONLY WAY I CAN SWITCH IT OFF NOW IF THE KEY IS NOT IN IS TO TAKE OFF THE HORN FUSE.
THE ALARM/IMMOBILISER STILL WORKS FINE. CAN SOMEONE PLEASE HELP.
I'VE HAD MY ML320 FOR 2YEARS NOW WITHOUT ANY PROBLEMS AT ALL.
#97
01 ML430 86 190D
I had same problem.Had power at CD changer but did not recognize at front unit.Replaced fuse R. Front kick panel fixed the problem.Also turned off SRS light.
#98
I got really excited reading this, as I have the same problem - "no CD player installed". BUT, when I removed said kick panel, there was no fuse R. The fuses and relays all have numbers. The list had nothing regarding the radio, changer, or any audio component. What year do you have??
#99
01 ML430 86 190D
FUSES RIGHT KICK PANEL
