Tie Rod End!
Old Nov 23, 2004 | 08:54 AM
drummerboy's Avatar
Tie Rod End!
I haven't read much about these failing. At 147000Km, I noticed the left side quite sloppy! Obviously, had been wearing for some time. Rattling noises in the front end.....which I thought were lose break pads .
Expecting a $300.00 tab on that one!
Anyone else? or is this not normal?
Old Nov 23, 2004 | 03:08 PM
Wintermute's Avatar
500SEC, ML430, SLK230, S600
Regarding the ML430, it is a documented problem.
Old Nov 23, 2004 | 03:58 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
At that sort of mileage I would not consider a worn tie rod end a problem. Its just worn out and should not even be considered an issue
Old Nov 27, 2004 | 10:13 AM
drummerboy's Avatar
Just an Update!
Job's done! Included an alignment! Cheaper than I thought!
Drives nice!
Now I can fall asleep behind the wheel a little longer...... j/k.
