Gas Tank Questions..?
Old Dec 2, 2004 | 10:32 AM
tkelley's Avatar
2001 ML 320
Ok lest talk capacity. Is the tank capacity on my ML 19 gallons total.... Or 19 + a 3 gallon reserve... Making the total 21..? I've averaged 20 mpg on the last trip but I'm really curious what the true range of the tank is? 380 miles on a 19 gallon tank. I'd really like to have a range of 450-500. Has anyone put in a larger tank..? Or a reserve tank in the place of the spare tire...? You could get a pretty large fuel cell there.
Old Dec 2, 2004 | 10:54 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Believe its somewhere between 19 and 20 without reserve. 02 and later have an increased capacity which I believe is 22 Gal
Old Dec 2, 2004 | 01:56 PM
ml320_2001's Avatar
Manual says 19Gal total.But I have observed that after the needle goes all the way to the bottom I still had 3 gallons.....
Old Dec 2, 2004 | 06:04 PM
saturnstyl's Avatar
Screwing with the fuel tank on an ML is pretty much a non-option. In theory an ML 55 fuel tank would do the trick, as it has a remote reservoir and higher capacity, which forces the spare to be in the cargo area also. Fuel tank R&R on an ML is not for the faint of heart, and this swap will probably entail further modifications I don't know about.
