2004 ML500 steering rack fluid leak
Old Dec 21, 2024 | 04:05 PM
NORAGRETS's Avatar
ML500
Fixing a 2004 ML 500 that belongs to a friend of mine. It’s been plagued by a power steering fluid leak for quite a while as I’ve been told. I just replaced the power steering pump, accessory belt and the power steering reservoir, but none of those ended up being the culprit. See video below. The problem is that the steering rack is dumping fluid where the tire rod connects to the actual steering rack. It only leaks when the car is on and the pump is working. Does the entire rack need replacement?
File Type: mov
Old Jan 24, 2025 | 01:40 AM
mihir_d's Avatar
2000 ML320 2006 SLK 350
Best option is to replace your steering rack with a rebuilt rack....the w163 rack is prone to leaks after about 10-12 years of service life....
