Looking to sell ML320 1998, 92K miles, mint interior
Old May 12, 2025 | 03:52 PM
venero's Avatar
Mercedes Benz ML320 1998
New on the forum here!
I have a Mercedes Benz ML320 in black with 92923 miles and mint interior (tan leather, power/heated seats, moonroof, extremely clean). Was looking to see what kind of offers the car would be able to get - have been getting a wide range from different sources. Would really appreciate the input!
Old May 13, 2025 | 11:14 AM
jay4usc's Avatar
2001 ML 320
when selling older cars, you should provide any major repairs you have already done (suspension, spark plug, fuel filter, etc)
Old May 14, 2025 | 01:50 AM
venero's Avatar
@jay4usc - Thank you for the suggestion!
I made the following repairs:
-brake system (calipers/wheel cylinders, rotors, pads)
-brake hardware cleaned and inspected
-fuel pump
-water pump
-transmission filter
-alternator
-serpentine belt
-canister vent solenoid
-dash lights
-driver side window switch
-oxygen sensor
-battery
-tires
-regular oil changes
Needed:
ABS sensor - most likely right rear speed sensor
Rear seal - small drip
AC compressor - small drip
Small evap leak
Paint
Old May 14, 2025 | 10:51 AM
chassis's Avatar
2017 GLE350 4MATIC
$7k. $8k if you are lucky and patient. The market for these is thin and in any case you will need to be patient. It would sell on Bring a Trailer.
It’s a 27 year old German car, not special in any collectible way. It looks nice. The interior is mint.
Old May 14, 2025 | 11:37 AM
jay4usc's Avatar
2001 ML 320
If you still have the original suspension, I would say around $5,000. My car is a 2001 with 104k miles and the most expensive maintenance was the suspension (struts/shocks, lower & upper control arms, tie rods, bushings) which cost around $5k. You can try to advertise it for more but I think $5,000 will be a sweet spot for a ‘98
good luck
Old May 18, 2025 | 03:24 PM
venero's Avatar
@chassis @jay4usc - thank you for the advice! That makes sense about the suspension, I will check in the prior service records to see if that was done before. And I did not know about the BAT option and will definitely try to submit, so I appreciate that suggestion as well.
