Low Fuel Warning Lamp?
Old Dec 20, 2004 | 05:08 PM
drummerboy's Avatar
I did a search and didn't find an answer.......so I'll ask!
The Low Fuel Warning indicator flashes for awhile and eventually quits. It's only the second time I've noticed it happening!
Tank is 3/4 - Full. Wondering if anyone has come across this and found a solution.
Is it something to be concerned about?
Thanks!
Old Dec 20, 2004 | 06:42 PM
saturnstyl's Avatar
It is a result of a major purge system leak. In layman's terms, check your fuel cap, I bet its loose.
Expect a check engine lamp to follow.
Old Dec 21, 2004 | 12:23 AM
drummerboy's Avatar
Thanks Again, Saturnstyl. And, Yes the CEL has appeared as well!
Will check Gas Cap!
Merry Christmas............Everybody!
