New "Command" in a 2001..?? $$$
Old Jan 21, 2005 | 01:35 AM
tkelley's Avatar
2001 ML 320
I'm thinking Saturnstyl will have the answer to this. How many pesos would it cost for the conversion to the Command 2.0 Units I see in the newer mercedes models...? I just sat in front of one yesterday and I like the interface alot more. I have an 01 with just the regular MCS with a changer in the rear. No Nav though.... Thanks.
Old Jan 21, 2005 | 02:30 AM
miroj's Avatar
All the MCS needs is a DVD reader for the map.
Old Jan 21, 2005 | 09:18 AM
tkelley's Avatar
2001 ML 320
Miroj, I'm talking about retrofitting the newer MCS Command Unit into an older ML.
Old Jan 21, 2005 | 04:04 PM
miroj's Avatar
I was under the impression that if you have the basic MCS head unit that all you would then need is the navigation processor.
Old Jan 21, 2005 | 04:51 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
I think by "MCS comand" he means "MCS2" which I am pretty sure all have navigation, although in his original post he talked about seeing a Comand 2.0 in a newer car (which I doubt) so I am not sure if he has actually seen an MCS2. And I don't think an MCS2 will physically fit into the dash of a W163 M-class.
-s-
Old Jan 21, 2005 | 04:57 PM
tkelley's Avatar
2001 ML 320
YES thats it. I used to have a link for a guy that showed pictures of his conversions. The hole is actually the same size... its just the face thats a different shape... I think..? I got the link from someone here... but can't find it anymore..
Old Jan 21, 2005 | 09:10 PM
ml350's Avatar
2005 ML 350
Hi,
are you talking about the new w164 mcs system?
Old Mar 9, 2009 | 09:13 AM
enea25's Avatar
w163 / w210
hi all
I been thinking of it too and i think it will fit if we switch the Low Range and the fog light switch somewhere else because i think the hole is the same for w163 and w164
