Transfer Case - Help !
Old Feb 17, 2005 | 09:22 PM
Nokia's Avatar
Hi !
Please,I need help.
1999 ML320 - What is wrong?
On max turn left or right - coming noise - some peoples call chatterening.
This is the problem of Transfer Case or front - CV joints.
I am just confused.
On 1999 Transfer Case ratio was change from 50/50 to 52/48.
What I need replace to make working properly.
torque split f / r after 10-19-98 48 - 52
Best Regards
Old Feb 19, 2005 | 01:22 PM
theboogers's Avatar
2020 S560,14 ml350, 03 sl55, silver, pano, slr cams, evo headers, lsd, 2019 s63 cab.
have the dealer check the side sensors for the sway of the car. it sounds like the esp thinks you are fishtaling and the front brakes are applied by the sensors.
Old Feb 20, 2005 | 07:05 PM
00ML430 Bulldog's Avatar
2000 ML430
Originally Posted by Nokia
Hi !
Please,I need help.
I am just confused.
Best Regards
New transfer case
Old Feb 21, 2005 | 02:03 AM
Nokia's Avatar
Thank you #3 00ML430 Bulldog !
You are very kind.
Regards.
Old Mar 6, 2005 | 06:54 PM
mbtech75ny's Avatar
chattering
the noise is coming from the transfer case. the dealership does have a updated planetary gear setup for the transfer case. which cures the problem.
Old Jun 10, 2010 | 07:22 PM
theologian's Avatar
ML320
Any word of a recall on transfer case issues regarding ML320 1999? Mine is starting to make noise at the 1-2 mph speed. Are bearings most likely the cause or this planetary gear mentioned above? Why is there an update the dealership has for the problem? Thanks in advance for any information...
Regards.
Old Dec 16, 2011 | 04:12 AM
oo0ronnie0oo's Avatar
audi a6 2.7t 2003
hey if you need im selling my transfer case for 2000 ml320 3.2 v6 its the same as your 500$ obo message me if you need it
