Thoughts on lack of starting....
Old Feb 18, 2005 | 12:27 PM
MDMB's Avatar
ML320
Question Thoughts on lack of starting....
Wondering if anyone has had this happen. Two seperate times one that I have witnessed, my wife has turned the key to start the truck and nothing. After a couple of tries it starts. It was like 4 months between incidents. The switch in the column, or some other common electrical gremlin?
Old Feb 18, 2005 | 12:51 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Had a similar problem. It became worse with time. Dealer said they lubed the flywheel. At the time I did not believe that would fix it, but it certainly did and I have not had a problem since. It did act like a bad switch or starter. My SA told me that the lack of lube caused the starter to shut off as if it had started.
