Accident Already
My car is pretty messed up, the front fender, front and rear door, rear fender and bumper are all damaged. The wheels are also misaligned now because in order to go straight the steering wheel has to be turned a little. Also, when the car is at a stop and I accelerate, it shudders.
Sh*tty part is that I had a stop sign and he didn't so it looks like it's my fault. But I was already 75% of the way through the intersection and he was speeding, but I have no way to prove that. I also have a slight suspicion he did it on purpose. What I think is that he sees a brand new Mercedes and he's in his sh*tty truck full of primer and thinks "hey if I total my car, I can get a new one paid by the insurance of that mercedes owner."
any thoughts on what I can do with this mess? Thanks in advance guys.
I can't help with the legal action, but you may want to contact your insurance in advance to talk them into footing the bill for an investigation to generate data in your favor or you could hire a lawyer. Either way, I'd get protected.
If in any possible way you can: GET RID OF IT!!! I had similar damage (also at two weeks) to a JGC, and nothing but trouble since. The bodyshop may and may not be able to straighten the body, but most likely you'll wind up with wind noise, binding doors and other delights. Furthermore, as your car was probably moving when hit, the entire driveline will have suffered a shock - my JGC went through more wheel bearings, rear diffs, and gearboxes than I'd care to think of. Even if the insurance company may hit you, get rid of it and let someone else "enjoy" the rebuild.
Cheers,
Birger
PS: It's a little hard to see from the photos: Are your 19" wheels standard or chrome??
Cheers,
Birger
PS. It does not matter what the other driver did if you had the stop sign. Its your fault for not waiting or looking. You only hope was excessive speed and measuring the skid marks. Wet road equals no skid marks. Bent metal is never pretty.
Good luck.
Red vette, thanks for the idea. I will probably do that, but the thing is my insurance company only gave me a check for the visual damage seen by the adjuster, for now. They said they would write a second or even third check as they find more damage along the way as it's being repaired.
Cheers,
Birger
Cheers,
Birger
Based on the pictures, that is a very light hit - no big deal to repair 100%. We are not yet to the point of throwing cars away, as so many people seem to think. If every car that was damaged the same way as that ML was, no one would be able to afford car insurance!
The key to getting your vehicle repaired correctly is to find a shop that is operating at a high level, a professional, a place that knows MB vehicles inside and out. MBUSA started a program to certify body shops (whether dealer owned or independant) based on thier qualifications, facilities, equipment, training, and on and on to insure that MB owners can have collision repairs handled in a proper way. One of the main elements of a good repair is the use of a dedicated fixture bench to insure that the vehicle's structure is 100% correct before rebuilding the parts. You may hear people refer to this as the Celette bench, however that is only one brand that is approved for use on MB vehicles. The other is Car Bench. If you choose a repair facility that is approved, they will be using this equipment - and that is a huge thing. Really, it's the foundation of a good repair.
Here is the link from MBUSA.com to help locate a certified center:
http://www.mbusa.com/brand/container...d.jsp&menu=3_0
Really, don't worry. Your car is completley repairable, and even more than that, it's not a big deal at all for a proper faclility to repair.
YOU may have a choice - look at my signature (I'm in Luxembourg, Europe), and generally, and particularly with "exotic" brands like Jeep, the choice is zero, here. This is not only true for body damage, but also in case of other major repairs - unfortunately. And most of the time, insurance will refuse to have your wreck taken to an experienced repair shop - out of state/country - because they hae certain "agreements".........
And even if I have a lot of confidence in the local MB dealer, in view of that damage, I'd try to get the insurance have it declared a total loss. Let them bother with reselling it - probably someone located 250+ miles east of here will be able to "fix" it to the delight of one of the local hoods.
Cheers,
Birger
Cheers,
Birger
I would look at the active work a body is doing on cars and see what their finished quality looks like. From what I have seen, a lot of body shops assign cars to certain people in their shop and they see the work thru completion. I would see how they do it and then select the one who does the best looking work. Get it fixed, try to sell it or trade it. Ask a local attorney in your area, what disclosure is necessary for the amount of vehicle damage thaat you have.
Best regards.
Jeff
The bodyshop will replace my front bumper, passenger side fender and headlight... I insist that my hood should be replaced as it is dent and scratched but the bodyshop says that it is repairable...
The estimate mounts to around $4,500.. Am I entitled for the diminished value in Illinois??... Should I just trade my car in (as is) and take the cash..
or should I repair it first then sell it??
I am afraid that if I keep my car, it will not be the same as before. Please give me some advices. Thanks.
Best regards.
