Battery question
Old Sep 15, 2005 | 09:47 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Battery question
Does any W164 owner know if their ML has 2 batteries like my 05 Eclass, one main and one for the electronics?? I have heard it does and it does not. Which is correct??
Old Sep 15, 2005 | 09:54 AM
PHYBENZ's Avatar
1963 220Sb
There is only battery I beleive and it is located under the front passenger seat.
Old Sep 15, 2005 | 11:41 AM
Nevada Jack's Avatar
2011 E350 Cabriolet..White and Almond Mocha
Check your manual Sosh but the R Class has two batteries located under the front passenger seat. I would suspect the ML is the same.
Old Sep 15, 2005 | 01:25 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
ML battery
The ML Owner's Manual, pages 462 - 469 only describes and shows one battery.
Old Sep 15, 2005 | 01:31 PM
Wolfgang's Avatar
MBs
And I found a 2 Volt battery in the R500? That'll be hard to start.
Old Sep 15, 2005 | 01:36 PM
In the R Walkaround guide it indicates there are 2 batteries. But in the R Manual it only shows one and directions for only one. So I can state at this point "I have no idea."
Old Sep 15, 2005 | 01:37 PM
"Use the Force Luke"
Old Sep 15, 2005 | 02:01 PM
sosh's Avatar
Can't check it do not yet have my ML. Any day now!!
Old Sep 20, 2005 | 06:37 AM
Petmerctech's Avatar
There are two batteries, the main one and a second small battery which is used only for the ISM (electronic shifter) to get it out of park, if the main battery is dead.
Old Sep 20, 2005 | 09:33 AM
2nd battery
Thanks--where is it located?
Old Sep 20, 2005 | 11:11 AM
Wolfgang's Avatar
MBs
2nd battery
It's also in the battery compartment under the right front seat, Greg, under the cover plate shown below. The heavier #1 battery is inboard, and the small #2 battery outboard of it.
Old Mar 24, 2009 | 12:05 PM
Skazz's Avatar
GL500
The R, ML, & GL all have 1 main battery and 1 12V 1.2Ah auxiliary battery located near the main one. It's just for the ISM as mentioned above, but not for getting it out of Park. It's for firing the transmission into Park in the event of a main electrical system failure / flat battery. It's deemed more important that the vehicle can be left restrained.
