will these wheels work for my car
Old Jul 13, 2006 | 01:30 PM
weeeza's Avatar
does anyone know if the offset on these wheels will work on a 2006 ml 350, the seller says they will but I am not sure
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA%3AIT&rd=1
thank you
Old Jul 13, 2006 | 02:52 PM
juank350's Avatar
ML350
I believe they will fit but will probably stand out to the sides just a bit because of the offset (ET). you will also have to use a staggered setup. 255/50/19 in the front and probably 275/40/19 in the rear
Old Jul 13, 2006 | 05:35 PM
weeeza's Avatar
so I cannot still use the same tires that currently came with the car 255/50/19, I have to go with a staggered fittment (I have the appearance package)
also souldn't the rear be 45 profile not 40, isn't that a big difference between front and rear, sorry I am not the best when it comes to tire sizes
the car only has 3k miles and I hate to waste the tires they are in excellent condition with a lot of tread left
thanks
sam
Old Jul 14, 2006 | 01:32 AM
weeeza's Avatar
Bump!
please guys help a newbie with this
Old Jul 14, 2006 | 03:48 AM
juank350's Avatar
ML350
I am pretty sure the front tires will fit but you will hace to ask a tire retailer if 9.5 widht rims will fit a 255 tire.. i believe with 275, 40 width tire will be the closest match. you can check at tirerack.com to see if the 255 will fit a 9.5 also. just select your tire make and under specificactions you will see the maximum rim width your tire will fit on.
