New TSB's ???
Old Oct 10, 2006 | 12:18 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
New TSB's ???
In a conversation with my SA yesterday re setting up a service appoint for my E Class he ran my VIN of my ML500 and found two new TSB's. First is on the gear change solinoid and involves a synch proceedure the second is the install of a shim in the exhaust system. Said that both should only take a half hour and he was not certain of exactly what they were supposed to correct. Told him I would make an appointment to bring it in and wait for it since its so simple.
Old Oct 10, 2006 | 03:16 PM
AutoSaurus's Avatar
1997 E320 Sedan
There are several TSB's and recall's out right now for the '06 ML. I had several completed just last week and notice a big improvement in the shifting. Also a few minor problems that kept popping up like oil light, SRS light, tailgate inoperable, etc.
Check out Alldata for more info.
Old Oct 10, 2006 | 06:54 PM
sosh's Avatar
The 2 I mentioned were the only open ones applicable to my VIN. The others may apply to earlier ML's. I have absolutly no problem with my tailgate or the shifting. Mine was delivered Sept 05 and was an early sept 05 build.
Old Oct 14, 2006 | 02:04 PM
idrive's Avatar
2017 SL63
wife's just went in.. they
rotated the tires
ISM motor, reprogrammed, cleaned
New exhaust brackets
All per MBUSA
the transmission updates had already been done.
Old Oct 15, 2006 | 08:22 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
TSBs
My 6/05 production 350 (12.8k mi.) was in the dealer 8/30. The following were performed:
- Campaign 2006010005 Suspension Plate Update (Airmatic)
Install 025080 plates at both upper control arms, 3.2 hrs.
- Driveline update TB41.10/03 (I brought in info on this one)
Replace bolts at driveshaft, 0.9 hrs
- Campaign 2006060002 164 Suspension Compressor
Check compressor for air suspension, 0.3 hrs.
- Campaign 2006060005 164 xhaust Bracket
Retrofit shim plate(s) between front exhaust system bracket and transmission, 0.4 hrs.
- Campaign 200608003 COMAND Navigation Software
Install software (BTW, this wipes out things you have in memory, incl. radio presets), 0.5 hrs.
Old Oct 15, 2006 | 08:32 PM
Recalls
No recalls that I know of, except for the steering hose clamp that only affected a small number of vehicles. Recalls are safety-related items that are government mandated. Service actions, campaigns and TSBs are considered less serious.
You can also find a list of TSBs and recalls at Edmunds.com:
http://www.edmunds.com/maintenance/M...ktid=ga9915285.
Old Oct 16, 2006 | 07:37 PM
sosh's Avatar
Greg, any idea of what the Command software update accomplishes?? The others that you mentioned are not or seem not to be applicable to my ML500 which was an early Sept 05 build. I do not even know yet if the command update is applicable. The only 2 I am aware of are the ones mentioned earlier in this thread.
Old Oct 16, 2006 | 10:06 PM
COMAND SW update
It avoids potential malfunctions due to incorrect software. Issued 8/1/2006. Read about it (with VIN list) here: http://www.alldata.com/tsb/Mercedes-...003/index.html
Old Oct 16, 2006 | 10:17 PM
sosh's Avatar
Greg, Thanks for the info. I have experienced no malfunctions at all and from the date I am assuming that my ML is up to date as so far as the command. It was built about a month after this was issued.
