Adjusting analog clock in instrument cluster
Old Mar 14, 2007 | 05:43 PM
Sentinelsf's Avatar
2014 CLS550, 20-inch TSW wheels
I was trying to adjust the "analog" clock in the speedo - and since I have COMAND with Nav, the manual refers me to the COMAND manual. The only instructions I found were for adjusting from Standard Time to Daylight Savings Time.
I must be missing it somehow - does any know how to adjust the clock?
I have a 07 ML350.
Old Mar 14, 2007 | 07:25 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
If you have Nav it is set thru the Command. Go to the SVC key, press the time button click on your time zone and a screen should appear with Std or DST. Move the curser to DST and click the OK button then watch your clock move. The clock is also kept in time with the received times from the satellites. Thats why its always right on. When doing all of that be certain either your engine is running or the key is in the run position.
Old Mar 14, 2007 | 08:36 PM
Sentinelsf's Avatar
I should have waited - figured it out this afternoon
Thanks for the reply - you were correct.
I set it to Pacific Daylight Savings Time when I was in my garage yesterday.
I took a drive after I posted this topic - it picked up the updated time from the satellite; this changed the clock in the speedo.
