- Mercedes-Benz C-Class: How to Program Garage Door Opener
Step by step instructions for do-it-yourself repairs
Browse all: Interior Guides
I have misplaced my manual on my 2002 ML500. I cannot remember how to program the garage door opener. I have the three buttons on the upper console next to the interior lights.
Thanks for your help D
Step 1:
_ Switch on the ignition
Step 2:
_ If you have previously programmed an
integrated signal transmitter button
and wish to retain its programming,
proceed to step 3. Otherwise, press
and hold the two outer signal transmitter
buttons 1 and 3 and release
them only when the indicator lamp
begins to flash after approximately
20 seconds (do not hold the button for
longer than 30 seconds). This procedure
erases any previous settings for
all three channels and initializes the
memory. If you later wish to program a
second and/or third hand-held transmitter
to the remaining two signal
transmitter buttons, do not repeat this
step and begin directly with step 3.
Step 3:
_ Hold the end of the hand-held remote
control transmitter of the device
you wish to train approximately 2 to
5 in away from the surface
of the integrated remote control
located on the left side of the interior
rear view mirror. Keep the indicator
lamp in view.
Step 4:
_ Using both hands, simultaneously
press the hand-held transmitter
button and the desired integrated
signal transmitter button (1, 2
or 3). Do not release the buttons until
completing step 5.
The indicator lamp on the
integrated remote control will flash,
first slowly and then rapidly.
Step 5:
_ When the indicator lamp flashes
rapidly, release both buttons.
Step 6:
_ Press and hold the just-trained
and observe the indicator lamp.
If the indicator lamp stays on
constantly, programming is complete
and your device should activate when
the integrated signal transmitter
button is pressed and released.
Step 7:
_ To program the remaining two buttons,
repeat the steps above starting with
step 3.
The indicator lamp flashes the first
time the signal transmitter button is
programmed. If this button has already
been programmed, the indicator lamp
will only start flashing after 20 seconds.
If the indicator lamp flashes rapidly
for about two seconds and then turns
to a constant light, continue with
programming steps 8 through 12 as
your garage door opener may be
equipped with the “rolling code”
feature.
Step 7:
step 3.
Rolling code programming
To train a garage door opener (or other
rolling code devices) with the rolling code
feature, follow these instructions after
completing the “Programming” portion
(steps 1 through 6) of this text. (A second
person may make the following training
procedures quicker and easier.) (Park
the car under the garage door motor)
Step 8:
_ Locate “training” button on the garage
door opener motor head unit.
Exact location and color of the button
may vary by garage door opener brand.
Depending on manufacturer, the
“training” button may also be referred
to as “learn” or “smart” button. If there
is difficulty locating the transmitting
button, refer to the garage door opener
operator’s manual.
Step 9:
_ Press “training” button on the garage
The “training light” is activated.
You have 30 seconds to initiate the
following step.
Step 10:
_ Firmly press, hold for two seconds and
release the programmed integrated
signal transmitter button (1, 2 or 3).
Step 11:
_ Press, hold for two seconds and
release same button a second time to
complete the training process.
Some garage door openers (or other rolling
code equipped devices) may require you to
perform this procedure a third time to
complete the training.
Step 12:
_ Confirm the garage door operation by
pressing the programmed integrated
