Front-end clunk when turning
See those three screws? Each one one them had to be tightened between 1/8 and 1/4 turn. I did this by hand, so I expect to be doing it again at some point, probably at the next service interval. In any case, this solved to clunking problem.
problem or noise is still there ...
I don't know if it's safe but it only happens at low speeds and with weight distribution and when cold.
Mercedes should figure this out or do a recall!!!
These screws need to be tightened.
I push down on front end and no sounds only when turn at low speeds and backing up and turning
what else could it be ? Control arms are next
