AC Dial Stuck
Old Dec 28, 2007 | 08:39 PM
Alabaster's Avatar
2006 ML350
AC Dial Stuck
This is wierd...has any one experienced turning the ac dial (on the driver side for me) only to find that when you turn it to go warmer the red light stays lit on the temp that is was already set to?
This happened several times today. Sometimes when I would turn it clockwise of off 72 degrees to the right the red light would stay put and not move (temp would not adjust either) or it would jump to the left and get colder, even though I was turning it to go warmer. Strange.
Old Dec 28, 2007 | 09:19 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Most likely a bad or defective HVAC module (dash unit) Not a big deal to change out and it should be under warranty.
Old Jun 7, 2010 | 06:09 PM
Zoweee's Avatar
r500
did you get this problem fixed....happened today to my r500....taking into dealer friday and want to be able to tell them what to look for.
Old Jun 7, 2010 | 07:58 PM
C-rod's Avatar
2014 ML350 BlueTec.
This is a known issue..............
on my prior M-Class, l was able to turn both dials, and the lights would not move.........Replaced unit.............under warranty...........
