Bolt diameter,thread pitch & threaded length of the ML 20'' AMG Wheel?
Old Feb 27, 2008 | 05:07 PM
alienx's Avatar
Thinking of ordering 10 or 15mm spacers, which requires that i also purchase new bolts. Anyone know the Bolt diameter,thread pitch & threaded length of the ML 20'' AMG Wheel?
Old Feb 27, 2008 | 05:59 PM
wonsuk_utmb's Avatar
2012 ML350 Bluetec
Alienx...
I dealt with this issue a while back. Bolt will be 14x1.5. I believe 45mm is the length of oem bolt from tip to the ball seat hub (measure to be sure by removing one bolt from your wheel). Remember 1 inch = 25.4mm. So if you get 15 mm spacers you would need to add 15mm to 45mm = 60mm. What is the width of your 20 inch wheel. The ml63 20" wheel already sticks out a little past the fenders on ml's without the optional amg fender flares. If it's the other 20" amg wheel which is 8.5 inches than I can understand. I hope that helps.
Old Feb 28, 2008 | 12:51 AM
alienx's Avatar
I have the ml63 20" wheel which is 10'' width, however i have the amg fender flares which make it look a bit tagged in, especially at the back.
Attached Thumbnails Bolt diameter,thread pitch & threaded length of the ML 20'' AMG Wheel?-image034.jpg
