DIY Brake Pad Change
Old May 30, 2008 | 07:55 PM
sdeason1's Avatar
2006 ML500
Can anyone tell me the size tool needed to remove the brake calipers from a 2006 ML500? These are the two piston calipers. It seems to be a 9mm (between 8mm and 10mm). Is there a special tool? Ate is the manufacturer. SAE? Thanks!
Old May 31, 2008 | 12:27 PM
lkchris's Avatar
'10 CL550, '12 GL550
You can purchase the W164 Service DVD at your dealer or by calling 800.for.merc
http://www.startekinfo.com/StarTek/o...stedDocId=9124
