Are ML & GL running boards the same?
Old Jan 25, 2009 | 11:03 PM
MBSL500AMG's Avatar
Hey guys I have simple question, are the ML & GL running boards are the same? Basically will the 07 GL running boards fit on my 06 ML?
Also, what tire pressure do you run on 08 ML350 with 19" rims?
Old Jan 26, 2009 | 12:05 PM
am_beagle's Avatar
08 ML350; 07' Acura RDX; 05'FX45; 03'Murano
I run my 08 ML tire pressure according to specs posted in the driver door column, which are 32 f and 38 r. If I like to have a smoother ride, I inflate the rear tires to 35/ 36 lbs.
Old Jan 26, 2009 | 02:28 PM
toothdr's Avatar
08 GL 450 / 09 ml 320 / 10 ml350
So your saying the length between the wheel wells is the same on the ml as the gl?
Old Jan 26, 2009 | 05:45 PM
BruNo's Avatar
07' ML350
No, They are Not the same
the GL has a longer running board, some bolt areas do not match. im sure coz the dealer made a mistake of sending me GL running boards which didnt fit my ML halfway thru the install.
