Comand backup camera input
Old Feb 10, 2009 | 08:28 PM
ste's Avatar
ste
2005 MINI Cooper S Conv, 2006 R350
I want to retrofit a backup camera to my car, so I bought a camera ready ML COMAND for my car (with a stick said "warning:check entire surrounding while backing"). After install, its screen turns black. I thought I just need to input the video signal to make it work, was told the video input is the pin 1&7 on the back. I got a Kenwood ccd2000 camera, but its NTSC output signal doesn't seam to work, also try a camera outs the PAL video signal, still not working ... now I am confused, does it need some other module to make it work? Has anyone done this before?
Old Feb 10, 2009 | 10:27 PM
am_beagle's Avatar
08 ML350; 07' Acura RDX; 05'FX45; 03'Murano
Star Diag, may be ?
Old Feb 10, 2009 | 10:33 PM
ste's Avatar
ste
The comand was taken off from a ML exported to EU, that has the B/U camera. I thought the B/U function has been enabled on it, that is why it turns black in reverse ... just missing the video input?
Old Feb 14, 2009 | 10:11 PM
ste's Avatar
ste
got it to work, was testing it with portable video source, that was the problem.
Old Feb 14, 2009 | 11:17 PM
am_beagle's Avatar
Smile
Please keep us posted.
Old Feb 16, 2009 | 09:56 PM
ste's Avatar
ste
Was cold outside today, but glad I got it done.
Attached Thumbnails Comand backup camera input-0216091456a.jpg   Comand backup camera input-0216091751.jpg
Old Feb 16, 2009 | 10:49 PM
am_beagle's Avatar
Please give us a write up, please............
Old Feb 16, 2009 | 11:17 PM
ste's Avatar
ste
Once I got it to work, the hard part is the install, pulling the rear door panel off, drill holes, and wire to the front. I have a R, so it doesn't fit the ML forum here.
Old Feb 16, 2009 | 11:19 PM
ste's Avatar
ste
Since my COMAND is already B/U enabled, so no dealer program needed. The function works just connect the camera output cable (RCA) to those pins on the back
I put the camera next to the door opener handle.
Old Mar 24, 2009 | 02:23 PM
scottshack's Avatar
w164
Did you cut open the RCA wire and just splice it in to the pins in the back of the unit? If you had a picture of the back that would be great, I am about to perform the same installation this weekend.
Old Mar 24, 2009 | 02:27 PM
scottshack's Avatar
w164
did you end up using a pal camera format or NTSC
Old Mar 24, 2009 | 11:15 PM
ste's Avatar
ste
Our COMANDs take NTSC format.
I have a old car radio that has RCA cables input, it is RCA female at one end and PIN connector on the other end. I just cut off one of these RCA cable for my use. The PIN goes into the black connector(a white connector next to it), 1&7 PINs are clearly marked. There is not female PIN inside, so you would need to get two small female PINS if you have them. The black connector locks those PINs done in place. Dealers may not selling those, but any small size PIN that fits will do. To make sure you got good connection, measure the resistance between the +/- of the RCA, and it shall be around 75 ohms. When test it with your camera, dont panic like me when I see no picture, I have to use the power source from the car to get picture.
Good luck, it should just work, like I have been told before too.
Old Dec 18, 2010 | 09:17 PM
fengfeng26's Avatar
ML350
does somebody knows that, which pin or what kind of adjustment to add back camera install with factory comand system.
