DEAD BATTERY ?
This Morning car did not unlock!!!!!!!!!!
call road Side ***.
DEAD BATTERY ....... No warning on the Display !!!!!
My wife is pretty upset.
6 months ownership, twice in Morning disapointments.
So much for so little
1st is a malfucting scm steering colum module which causes a draw.. and also a incorrect software in the rear sam.
the dealer should know about this update
If the battery has discharged for whatever reason while it has been parked for whatever length of time, and you open the vehilce with the mechanical key, there is no way that any display can be given to indicate this..........there is no power supply!
I'm not questioning why the battery went flat, that's a job for you're local dealer to determine. I'm questioning the unreasonable expectations of the vehilce by the owner to indicate that the battery is totally discharged.
Mar 11, 2009
T-B-54.21/198f
Revision: Remedy 3 Added
Model 164.122/172/177/186/822/871/886, 251.122/156/165, Model Year 2008
Battery Discharging - Increased Rest Current in the Rear SAM / CAN Bus Awake
Mode Software in Steering column Module (SCM)
