Rear Sam and Trailer Wiring
Thanks,
Joe
my 2008 did not come with a trailer hitch, if it has no hitch it will not have?? a brake controller harness.
when the dealer installed the hitch along with the new sam, which disengages the parktronic system when you hook up your trailer. The wiring harness that comes with the SAM is a 4 pin which you can then hook up to your brake controller.If you have a hitch installed this green harness is either in the rear by the fuse panal- pre 2007model, or under the dash post 2007, remove the three torq screws which you will find near the diagnostic plug above the brake pedal, it is either taped to the diagnostic cable or on the steering column, this took me a lot of research with the help of the local dealer i phoned MB about this the engineers could not answer the question- do all ml320 cdi come with the harness, they said they would have to contact the factory, still no answer i was also told that there has been a few complaints about the whole towing issue. if you need more info let me know
