Can you replace only one tire?
Old Jul 27, 2009 | 08:38 PM
Fireleg's Avatar
2006 ML500
I have 8k miles on my continental 4x4 contacts and one tire has a tiny hole in the sidewall. Is it really going to damage the drivetrain if I replace only that tire? Is 8k mile enough to reduce the over all diameter of the tire to cause damage with one new tire?
As you can guess I'm not thrilled to replace all four tires.
2006 ML500 w/Appearance pkg.
Old Jul 27, 2009 | 11:56 PM
rkao's Avatar
'12 ML350
Yes, it should be safe to replace only one tire provided you use the exact same tire as the others in terms of manufacturer, model, and size. Be careful to make sure to find the OEM replacement as some tire manufacturers make a specific model of tire for a vehicle manufacturer - sometimes denoted with the N0 or N1 mark.
Old Jul 28, 2009 | 09:06 AM
Fireleg's Avatar
2006 ML500
Thank you very much for the info.
Old Jul 28, 2009 | 09:33 AM
roadrutz's Avatar
'09 ML550
One word of caution: Depending on how you drive, your damaged tire could be quite worn down. That means that a new tire may have different grip qualities than the remaining original, and they will be on opposite sides of the vehicle. Rule of thumb is to replace tires on both sides if they are worn more than 50% and one needs replacing. Even though he obviously has an incentive to sell you two tires rather than one, I would ask my dealer's or tire supplier's opinion on this.
Old Jul 28, 2009 | 10:54 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
With only 8000 miles on the vehicle thats about 15 to 25 % of tire wear and you should be fine replacing only one but with any more miles on it I would replace a pair.
Old Jul 31, 2009 | 09:26 AM
Mikemcn's Avatar
15 C300 Sport SOLD!!! :)
I believe the N marks are Porsche-specific (meaning Porsche has tested and accepted these for use on their cars). There are other marks for Audi and some others, not sure if MBZ or BMW have ever done this. Tirerack is a good place to look.
