Crazy trailer hitch wire problem
I have an 08 ML 350 with factory trailer hitch, factory wired. my brother also has an 08 ML 350 with the factory trailer hitch and factory wiring. He has a small boat trailer that when pluged into his ML works perfectly, when I hook up the trailer to my ML and plug it in none of the lights work correctly, they all work but in the wrong locations on the trailer, pressing the brake pedal lights the running lights on the trailer, the turn signal lights the incorrect signal on the trailer etc. It seems as if the factory harness on my car has been wired wrong, My brother also has a pick up truck that when is hooked up to the trailer works fine, and someone else just towed the trailer with their Dodge truck last week and it also worked fine. I know this sounds crazy and impossible, but any other vehicle when hooked up to the trailer works fine. I wonder if there is a way for the dealer to change which pins on the 7 pin harness via the computer in the ML? I cannot belive that M.B. did not wire the harness correctly. Can anyone help with info
