Dome light problem
Old Jun 24, 2010 | 01:57 AM
joester's Avatar
Dome light problem
Need help. All my interior light and sun roof are not working. Fuses looks good. Light for those switchs on the dome and rear mirror strays on. Will not turn off even with all doors close. Any help is much appreciated.
Also does anyone know how to remove the dome light?
Attached Thumbnails Dome light problem-dsc04078.jpg   Dome light problem-dsc04074.jpg
Old Jun 24, 2010 | 09:47 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Have you checked your fuses?? That would be the first step.
Old Jun 24, 2010 | 10:15 AM
Vernl's Avatar
ML320CDI 2008 all options inc air suspension
I'm afraid you cant just look at a fuse to see if its good....ideally you use an ohm meter to check continuity...but if you dont have one, either try the fuse in something else you know is working or throw in another fuse...then move on to the next step if you still get no results.Your manual will tell you how to replace the bulb in the interior light.
Old Jun 24, 2010 | 01:46 PM
joester's Avatar
Fuse is still good. All interior light are out. Sun roof will not open. For some reason all switches where the dome light are lite up. The little light where the garage opener button is also on. Light is always on, will not turn off.
